This stainless steel element is entirely made of stainless steel: the element itself and the base. The element itself has been polished to be shiny, smooth and easy to clean.
This 3200W element has a base to tip length of 32cm and a foldback length of 27 cm. It is a good fit for any kettle with a diameter of 35cm and bigger.
For brewing, you want a low watt density element: the power per square centimeter should be as low as possible to prevent scorching. This element has a watt density of 11W per cm2, which is very low.
See the table below for the how much current the element will draw.
Voltage 230 V 240 V Power 3200 W 3500 W Current 13.9 A 14.6 A Note: always consult an electrician for advice and help with wiring your elements! Under no circumstances should these be used without proper wiring, ground fault circuit protection and overcurrent circuit protection.
Voltage 230V Watt density 11 W / cm2 Power at 230V 3200 W Current at 230V single-phase 15.2 A Current at 230V 3-phase - Thread 1" BSP Hole punch size 1 1/4" / 31.75 mm - Reviews
Customer Reviews 1 item(s)
- Good quality, easy to clean
Good quality, easy to clean, and the wort does not get scorched burned around the element
Price Value Quality
Stainless Steel Foldback Heating Element 2800W (27cm)
Excl. Tax: €27.00 Incl. Tax: €32.67 -
Round Heating Element for brewing, 30cm diameter, 3200W
Excl. Tax: €89.00 Incl. Tax: €107.69 -
Round Heating Element for brewing, 35cm diameter, 3500W
Excl. Tax: €99.00 Incl. Tax: €119.79
