Heating element mounting kit 1"NPS (camco compatible)
Excl. Tax: €45.00 Incl. Tax: €54.45
Ultra durable, watertight, stainless steel heating element enclosure.
With this stainless steel heating element mount, you can mount your heating elements in your kettle in a safe and beautiful way. The enclosure consists of two parts that screw together, and is made of stainless steel. These things are durable, they way over 0.5 kg!
This enclosure is suitable for Camco elements with a 1" NPS thread. We also have as kit for our single phase heating elements with 1" BSP.
The heating element is not included! Please order one separately.
On the inside, there is a hex hole to hold the element in place. Next to that hole is a small M4 threaded hole to ground the enclosure. Because the enclosure is pressed against the kettle, this will ground the entire kettle for safety.
On the front, there's an O-ring groove for a standard 218 O-ring. When the enclosure is pressed against the kettle, this will create a watertight seal.
On the back is a threaded hole for an M25 cable gland.
Material: SS304 stainless steel. Diameter: 60mm Height: 60mm
This kit includes:
  • Stainless mounting kit body
  • O-ring (size 218, used between kettle and mounting kit)
  • Flat gasket (used between element base and enclosure)
  • 1" BSP locknut
  • Cable gland
  • Eye lugs
  • Grounding bolt
Cable is not included, but available separately.
Click here for the installation manual (PDF)
