Round Heating Element for brewing, 35cm diameter, 3500W
Excl. Tax: €119.00 Incl. Tax: €143.99
Round stainless steel ultra low watt density heating element for brewing, 35 cm diameter, 3500W.
We have completely redesigned our single phase heating element with a round loop, a new custom flange and a new custom stainless steel housing. These new elements have several advantages over straight or foldback elements:
  • Because of the extra length, they have really low watt density.
  • Because of the round shape, they have better heat distribution in the kettle.
  • The round shape doesn’t get in the way of a good whirlpool.
  • The flange has an integrated O-ring, which is completely hidden once mounted.
  • The flange has a middle screw for grounding to ensure safe operation.
  • The custom mounting kit makes it very easy to mount them in any kettle. You only need a 47mm hole punch and a large wrench (54mm).
1 phase 230V
Power 3500W
Current 15.2A
Watt density 10.7 W / cm2
Minimum kettle size 41 cm
Designed for kettle size 45 cm
Voltage 230V
Power at 230V 3500 W
Current at 230V single-phase 15.2 A
Current at 230V 3-phase -
Thread 1.5" BSP
Hole punch size 47 mm
