24V immersable pump (for cooling with glycol)
Excl. Tax: €30.00 Incl. Tax: €36.30 -
Tri-Clamp heating element for brewing - 32 cm - 5500W in 3 loops - 2 inch clamp (64 mm)
Excl. Tax: €115.00 Incl. Tax: €139.15Out of stock
Round Heating Element for brewing, 25cm diameter, 2800W
Excl. Tax: €109.00 Incl. Tax: €131.89 -
Q.max Sheet Metal Hole Punch 32.5 mm
Excl. Tax: €15.50 Incl. Tax: €18.76 -
Heating element mounting kit 1"NPS (camco compatible)
Excl. Tax: €45.00 Incl. Tax: €54.45 -
Heating element mounting kit 1"BSP
Kettle inlet kit with hose barb, 1/2" NPT
Excl. Tax: €25.00 Incl. Tax: €30.25 -
Kettle inlet kit with hose barb, 1/2" BSP
Whirlpool Inlet Kit 1/2" BSP - 25 cm
Excl. Tax: €29.00 Incl. Tax: €35.09
