Whirlpool Inlet Kit 1/2" BSP - 45 cm
Excl. Tax: €33.00 Incl. Tax: €39.93 -
Whirlpool Inlet Kit 1/2" BSP - 35 cm
Excl. Tax: €31.00 Incl. Tax: €37.51 -
Whirlpool Inlet Kit 1/2" NPT - 45 cm
Whirlpool Inlet Kit 1/2" NPT - 25 cm
Excl. Tax: €29.00 Incl. Tax: €35.09 -
Whirlpool Inlet Kit 1/2" NPT - 35 cm
Tri-Clamp heating element for brewing - 42 cm - 8500W in 3 loops - 2 inch clamp (64 mm)
Excl. Tax: €129.00 Incl. Tax: €156.09Out of stock
Tri-Clamp heating element for brewing - 52 cm - 10000W in 3 loops - 2 inch clamp (64 mm)
Excl. Tax: €145.00 Incl. Tax: €175.45Out of stock
24V brewing pump with PWM speed input and mounting bracket
Excl. Tax: €142.50 Incl. Tax: €172.43Out of stock
Round Heating Element for brewing, 70cm diameter, 15000W
Excl. Tax: €339.00 Incl. Tax: €410.19 -
Whirlpool Inlet Kit 1/2" NPT - 20 cm
Excl. Tax: €28.00 Incl. Tax: €33.88
