Tri-Clamp heating element for brewing - 42 cm - 8500W in 3 loops - 2 inch clamp (64 mm)
Excl. Tax: €129.00 Incl. Tax: €156.09
Tri-Clamp low watt density heating element for brewing.
Tri-Clamp heating element for 2" inch tri-clamp ferrule (64mm OD).
  • SS316 stainless steel 11mm loops
  • 3 loops/resistors. Can be configured as 3-phase star configuration or as 1-phase parallel.
  • Stainless steel cover and cable gland included
230V
Power 8500W total
Current 3x12.3A or 1x37A
Watt density 11.7 W / cm2
Minimum kettle size 42 cm
Voltage 230V
Power at 230V 8500 W
Current at 230V single-phase 37A
Current at 230V 3-phase 12.3A
Thread No
Hole punch size No
