Round Heating Element for brewing, 40cm diameter, 8500W
Excl. Tax: €160.00 Incl. Tax: €193.60
Round stainless steel ultra low watt density heating element for brewing, 40cm diameter.
We have completely redesigned our heating elements with round loops, a new custom flange and a new custom stainless steel housing. These new elements have several advantages over straight or foldback elements:
  • More power means faster rise times and a more vigorous boil.
  • Because of the extra length, they have really, really low watt density. They simply do not scorch. You don’t have to scrub after brewing.
  • Because of the round shape, they have better heat distribution in the kettle.
  • The round shape doesn’t get in the way of a good whirlpool.
  • The flange has an integrated O-ring, which is completely hidden once mounted.
  • The flange has a middle screw for grounding to ensure safe operation.
  • The custom mounting kit makes it very easy to mount them in any kettle. You only need a 47mm hole punch and a large wrench (54mm).
The elements can be used as 3-phase or as single phase element by re-arranging the connector plates on the back (see photos).
3 phase 230V (Y- or star configuration)
1 phase 230V
Power 8500W
Current 3 x 12.3 A or 1 x 37A
Watt density 6.5 W / cm2
Minimum kettle size 46 cm
Voltage 230V or 3 x 230V
Watt density 6.1 W / cm2
Power at 230V 8500 W
Current at 230V single-phase 37 A
Current at 230V 3-phase 3 x 12.3 A
Thread 1.5" BSP
Hole punch size 47 mm
