We have completely redesigned our heating elements with round loops, a new custom flange and a new custom stainless steel housing. These new elements have several advantages over straight or foldback elements:
- More power means faster rise times and a more vigorous boil.
- Because of the extra length, they have really, really low watt density. They simply do not scorch. You don’t have to scrub after brewing.
- Because of the round shape, they have better heat distribution in the kettle.
- The round shape doesn’t get in the way of a good whirlpool.
- The flange has an integrated O-ring, which is completely hidden once mounted.
- The flange has a middle screw for grounding to ensure safe operation.
- The custom mounting kit makes it very easy to mount them in any kettle. You only need a 47mm hole punch and a large wrench (54mm).
The elements can be used as 3-phase or as single phase element by re-arranging the connector plates on the back (see photos).
Voltage 3 phase 230V (Y- or star configuration)
1 phase 230V
Power 8500W Current 3 x 12.3 A or 1 x 37A Watt density 7.5 W / cm2 Minimum kettle size 41 cm Designed for kettle size 45 cm Element material SS316 stainless steel Flange and housing material SS304 stainless steel Certification CE
Note: always consult an electrician for advice and help with wiring your elements! Under no circumstances should these be used without proper wiring, ground fault circuit protection and overcurrent circuit protection. - Additional Information
Voltage 230V or 3 x 230V Watt density 7.5 W / cm2 Power at 230V 8500 W Current at 230V single-phase 37 A Current at 230V 3-phase 3 x 12.3 A Thread 1.5" BSP Hole punch size 47 mm - Reviews
Round Heating Element for brewing, 40cm diameter, 8500W
Excl. Tax: €189.00 Incl. Tax: €228.69
