Dip Tube Kit BSP
Dip Tube Kit BSP
Excl. Tax: €22.00 Incl. Tax: €26.62
Low profile dip tube with 1/2" BSP fitting with integrated O-rings
This low profile diptube can be used to suck up water or wort from the bottom of your kettle. The height from fitting center to the bottom is only 2.5cm!
The BrewPi fitting and locknut will make it very easy to install and will guarantee a watertight seal.
Tube outer diameter: 12mm
