Kettle inlet kit with hose barb, 1/2" BSP
Excl. Tax: €25.00 Incl. Tax: €30.25
90 degree kettle inlet with hose barb and 1/2" BSP fitting with integrated O-ring
  • Description
  • Reviews
This kettle inlet has a 90 degree angle so you can pump water or wort into your kettle without splashing: the curved stainless steel tube will be aimed at the kettle wall.
The stainles steel tube ends in a hose barb, so you can attach a silicone tube to gently recirculate your the wort onto your grain bed.
The BrewPi fitting and locknut will make it very easy to install and will guarantee a watertight seal.
Tube outer diameter: 12mm
