Tri-Clamp heating element for 2" inch tri-clamp ferrule (64mm OD).
- SS316 stainless steel 11mm loops
 - 3 loops/resistors. Can be configured as 3-phase star configuration or as 1-phase parallel.
 - Stainless steel cover and cable gland included
Voltage 230V
Power 10000W total Current 3x14.5A or 1x43A Watt density 10.7 W / cm2 Minimum kettle size 52 cm Element material SS316 stainless steel Flange and housing material SS304 stainless steel Certification CE
Note: always consult an electrician for advice and help with wiring your elements! Under no circumstances should these be used without proper wiring, ground fault circuit protection and overcurrent circuit protection. - Additional Information
Voltage 230V Watt density 10.7 W / cm2 Power at 230V 10000 W Current at 230V single-phase 43A Current at 230V 3-phase 14.5A Thread No Hole punch size No  - Reviews
            Round Heating Element for brewing, 35cm diameter, 3500W
Excl. Tax: €119.00 Incl. Tax: €143.99
