Tri-clamp heating element for brewing - 42 cm - 5000W in 2 loops - 2 inch clamp (64 mm)
Excl. Tax: €109.00 Incl. Tax: €131.89
Tri-clamp low watt density heating element for brewing.
Triclamp heating element for 2" inch tri-clamp ferrule (64mm OD).
  • SS316 stainless steel 11mm loops
  • 2 loops/resistors, each 1600W
  • Stainless steel cover and cable gland included
230V
Power 3200W total
Current 1x22A or 2x11A
Watt density 10.3 W / cm2
Minimum kettle size 42 cm
Voltage 230V
Power at 230V 5000 W
Current at 230V single-phase 1x 22A or 2x 11A
Current at 230V 3-phase -
Thread No
Hole punch size No
