Tri-clamp heating element for brewing - 35 cm - 3200W in 2 loops - 2 inch clamp (64 mm)
Excl. Tax: €95.00 Incl. Tax: €114.95
Tri-clamp low watt density heating element for brewing.
Triclamp heating element for 2" inch tri-clamp ferrule (64mm OD).
  • SS316 stainless steel 11mm loops
  • 2 loops/resistors, each 1600W
  • Stainless steel cover and cable gland included
230V
Power 3200W total
Current 13.9A
Watt density 8.3 W / cm2
Minimum kettle size 35 cm
Voltage 230V
Power at 230V 3200 W
Current at 230V single-phase 13.9
Current at 230V 3-phase -
Thread No
Hole punch size No
