                        DetailsTri-Clamp heating element for 2" inch tri-clamp ferrule (64mm OD). - SS316 stainless steel 11mm loops
- 3 loops/resistors. Can be configured as 3-phase star configuration or as 1-phase parallel.
- Stainless steel cover and cable gland included
 Voltage 230V Power 5500W total Current 3x8A or 1x24A Watt density 10.6 W / cm2 Minimum kettle size 32 cm Element material SS316 stainless steel Flange and housing material SS304 stainless steel Certification CE
                        Additional InformationVoltage 230V Watt density 10.6 W / cm2 Power at 230V 5500 W Current at 230V single-phase 24A Current at 230V 3-phase 8A Thread No Hole punch size No
                  Round Heating Element for brewing, 35cm diameter, 3500WExcl. Tax: €119.00 Incl. Tax: €143.99
