Tri-Clamp heating element for 2" inch tri-clamp ferrule (64mm OD).
- SS316 stainless steel 11mm loops
- 2 loops/resistors, each 1400W
- Stainless steel cover and cable gland included
Voltage 230V
Power 2800W total Current 12.2 Watt density 8.8 W / cm2 Minimum kettle size 30 cm Element material SS316 stainless steel Flange and housing material SS304 stainless steel Certification CE
Note: always consult an electrician for advice and help with wiring your elements! Under no circumstances should these be used without proper wiring, ground fault circuit protection and overcurrent circuit protection. - Additional Information
Voltage 230V Watt density 8.8 W / cm2 Power at 230V 2800 W Current at 230V single-phase 1x 12,2A, 2x 6,1A Current at 230V 3-phase - Thread No Hole punch size No - Reviews
Round Heating Element for brewing, 35cm diameter, 3500W
Excl. Tax: €119.00 Incl. Tax: €143.99
