Our stainless steel HERMS coils are ideal for use in any kettle: the only thing you will have to do is make two holes in the kettle with a 21mm hole punch.
This coil is 7.5 meters long, because we calculated and tested that this is the ideal length.
The HERMS coil comes with two 1/2" NPT stainless steel fittings with integrated O-ring groove.
These fittings are custom designed by BrewPi. We designed them with the following in mind:
- The fitting is easy to install: just put it through the hole and put a locknut on the outside.
- Once installed, the O-ring is completely hidden and protected by the stainless steel.
- The O-ring has 20% compression and 20% free goove volume, for a good seal and a long life span.
- The length of the thread is 3/4 inch, so after adding the locknut, you still have enough length for a ball valve or camlock fitting.
The fittings are mounted onto the coil with a hydraulic press at the factory. This is watertight and very strong. 100% guaranteed: if the fitting leaks, you will get a 100% refund.
Tube length: 7.5m Wall thickness: 0.5mm Material: SS304 stainless steel O-ring seal: Food grade silicone Spanner size: 32mm Thread type: NPT (American), if not American you'll probably want BSP - Reviews
Stainless Steel HERMS Coil with BSP Fittings - 30 cm - 7.5m
Excl. Tax: €99.00 Incl. Tax: €119.79
