Stainless Steel HERMS Coil with BSP Fittings - 30 cm - 7.5m
Excl. Tax: €99.00 Incl. Tax: €119.79
30cm HERMS coil with BSP fittings and integrated O-rings.
Our stainless steel HERMS coils are ideal for use in any kettle: the only thing you will have to do is make two holes in the kettle with a 21mm hole punch.
This coil is 7.5 meters long, because we calculated and tested that this is the ideal length.
The HERMS coil comes with two 1/2" BSP stainless steel fittings with integrated O-ring groove.
These fittings are custom designed by BrewPi. We designed them with the following in mind:
  • The fitting is easy to install: just put it through the hole and put a locknut on the outside.
  • Once installed, the O-ring is completely hidden and protected by the stainless steel.
  • The O-ring has 20% compression and 20% free goove volume, for a good seal and a long life span.
  • The length of the thread is 3/4 inch, so after adding the locknut, you still have enough length for a ball valve or camlock fitting.
The fittings are mounted onto the coil with a hydraulic press at the factory. This is watertight and very strong. 100% guaranteed: if the fitting leaks, you will get a 100% refund.
Tube length: 7.5m
Wall thickness: 0.5mm
O-ring seal: Food grade silicone
Spanner size: 32mm
Thread type: BSP, used almost everywhere except the USA
Customer Reviews 1 item(s)
Excellent!
Great quality HERMS coil. The craftsmanship is amazing and with 10 minutes of work you can add the coil to your HLT.
Quality
Price
Value
Review by Daniel / (Posted on 4/24/2020)
