Threaded OneWire Temperature Sensor NPT 1/2"
Excl. Tax: €18.00 Incl. Tax: €21.78
  • Buy 5 for €16.50 (€19.97 incl. tax) each and save 9%
  • Buy 10 for €15.00 (€18.15 incl. tax) each and save 17%
1/2" threaded temperature sensor silicone cable and RJ12 plug
This sensor is specifically designed to fit into a threaded 1/2" NPT tee fitting. The sensors are made from SS316 stainless steel and have a detachable cable.
Specs:
  • Plug and play with the BrewPi Spark
  • Maxim DS18B20 sensor
  • RJ11 connector (fits RJ12 socket)
  • 1.5m silicone detachable cable (high temperature proof)
  • Stainless steel SS316
  • Probe length: 12.7 mm (0.5 inch)
  • Thread length: 12.7 mm (0.5 inch)
  • 0.0625 ºC resolution
  • Range of -55°C to +125°C
  • Factory accuracy of ±0.5°C over the range of -10°C to +85°C
  • With calibration via the BrewPi software, accurate to 0.0625 °C
Warning: not compatible with other PID controllers, like the STC-1000. These devices need an analog thermocouple sensor. This is a digital OneWire sensor.
