Silicone hose / tubing (food grade, 12mm inner diameter, 4mm wall thickness)
Excl. Tax: €6.00 Incl. Tax: €7.26
FDA grade silicone tubing, 12mm inner diameter, 4mm wall thickness.
This silicone tube has an extra wide 12mm inner diameter and extra thick walls (4mm).  It provides better isolation and does not kink.
Made in Germany.
FDA food grade silicone is the ideal material for your hoses for 4 reasons:
  • It is food safe
  • It can withstand heat up to 300 degrees Celsius
  • It does not leave a taste and does not smell
  • It is transparent so you can see your beer flow
When you have a pressure of over 1 bar we advise you to use our reinforced silicone hose.
Price is per meter, but you will receive your ordered quantity in one piece. So if you order this product 5 times, you will receive a 5m tube.
