3-piece full bore ball valve with locking handle (1/2" BSP)
Excl. Tax: €15.00 Incl. Tax: €18.15Out of stock
1/2" BSP Elbow (male - female) - 45 degrees
Excl. Tax: €2.40 Incl. Tax: €2.90 -
1/2" BSP Elbow (female - female) - 45 degrees
Excl. Tax: €2.20 Incl. Tax: €2.66 -
1/2" NPT female (Type A) Camlock Fitting
Excl. Tax: €4.80 Incl. Tax: €5.81 -
1/2" NPT male (Type F) Camlock Fitting
Excl. Tax: €5.30 Incl. Tax: €6.41 -
Stainless Steel HERMS Coil with BSP Fittings - 30 cm - 7.5m
Excl. Tax: €99.00 Incl. Tax: €119.79 -
One Way Valve (Swing Check Valve) 1/2" BSP
Excl. Tax: €14.00 Incl. Tax: €16.94 -
Q.max Sheet Metal Hole Punch 21mm
Excl. Tax: €13.50 Incl. Tax: €16.34 -
