Round Heating Element for brewing, 70cm diameter, 15000W
Excl. Tax: €339.00 Incl. Tax: €410.19 -
Whirlpool Inlet Kit 1/2" NPT - 20 cm
Excl. Tax: €28.00 Incl. Tax: €33.88 -
Whirlpool Inlet Kit 1/2" BSP - 20 cm
Tri-Clamp 50.5mm to 1 inch BSP adapter large inner diameter
Excl. Tax: €9.00 Incl. Tax: €10.89Out of stock
Reinforced silicone hose / tubing (food grade, 14mm inner diameter, 4mm wall thickness)
Excl. Tax: €9.00 Incl. Tax: €10.89 -
1" NPS locknut for Camco heating element
Excl. Tax: €5.00 Incl. Tax: €6.05
