1/2" BSP male (Type F) Camlock Fitting
Excl. Tax: €5.30 Incl. Tax: €6.41 -
1/2" BSP female (Type A) Camlock Fitting
Excl. Tax: €4.80 Incl. Tax: €5.81 -
Barb (Type C) Camlock Fitting - High Flow
Excl. Tax: €8.50 Incl. Tax: €10.29 -
Silicone hose / tubing (food grade, 12mm inner diameter, 4mm wall thickness)
Excl. Tax: €6.00 Incl. Tax: €7.26 -
2-piece full bore ball valve with locking handle (1/2" BSP)
Regular Price: €12.10
Special Price Excl. Tax: €9.00 Incl. Tax: €10.89
Out of stock
Q.max Sheet Metal Hole Punch 47mm
Excl. Tax: €22.00 Incl. Tax: €26.62 -
Tri-Clamp heating element for brewing - 42 cm - 5000W in 2 loops - 2 inch clamp (64 mm)
Excl. Tax: €119.00 Incl. Tax: €143.99 -
Tri-Clamp heating element for brewing - 30 cm - 2800W in 2 loops - 2 inch clamp (64 mm)
Excl. Tax: €99.00 Incl. Tax: €119.79 -
Tri-Clamp heating element for brewing - 52 cm - 10000W in 3 loops - 2 inch clamp (64 mm)
Excl. Tax: €145.00 Incl. Tax: €175.45 -
Tri-Clamp heating element for brewing - 42 cm - 8500W in 3 loops - 2 inch clamp (64 mm)
Excl. Tax: €129.00 Incl. Tax: €156.09
