1" NPS locknut for Camco heating element
Excl. Tax: €5.00 Incl. Tax: €6.05 -
1/2" BSP Elbow (female - female) - 45 degrees
Excl. Tax: €2.20 Incl. Tax: €2.66 -
1/2" BSP Elbow (male - female) - 45 degrees
Excl. Tax: €2.40 Incl. Tax: €2.90 -
3-piece full bore ball valve with locking handle (1/2" BSP)
Excl. Tax: €15.00 Incl. Tax: €18.15Out of stock
One Way Valve (Swing Check Valve) 1/2" BSP
Excl. Tax: €14.00 Incl. Tax: €16.94 -
Q.max Sheet Metal Hole Punch 47mm
Excl. Tax: €22.00 Incl. Tax: €26.62 -
Q.max Sheet Metal Hole Punch 21mm
Excl. Tax: €13.50 Incl. Tax: €16.34 -
Low profile 3-phase SSR heat sink
Excl. Tax: €12.50 Incl. Tax: €15.13 -
1" BSP locknut for heating element
