Tri-Clamp 50.5mm to 1 inch BSP adapter large inner diameter
Excl. Tax: €9.00 Incl. Tax: €10.89 -
Reinforced silicone hose / tubing (food grade, 14mm inner diameter, 4mm wall thickness)
Tri-Clamp 50.5mm to hose barb adapter (1/2" ID)
Excl. Tax: €11.50 Incl. Tax: €13.92 -
Tri-Clamp 50.5mm to 1/2" BSP adapter
Tri-Clamp heating element for brewing - 35 cm - 3200W in 2 loops - 2 inch clamp (64 mm)
Excl. Tax: €105.00 Incl. Tax: €127.05 -
Tri-Clamp heating element for brewing - 42 cm - 5000W in 2 loops - 2 inch clamp (64 mm)
Excl. Tax: €119.00 Incl. Tax: €143.99 -
Tri-Clamp heating element for brewing - 30 cm - 2800W in 2 loops - 2 inch clamp (64 mm)
Excl. Tax: €99.00 Incl. Tax: €119.79 -
Tri-Clamp heating element for brewing - 52 cm - 10000W in 3 loops - 2 inch clamp (64 mm)
Excl. Tax: €145.00 Incl. Tax: €175.45 -
Bulkhead fitting kit (1/2" NPT)
Excl. Tax: €18.00 Incl. Tax: €21.78
