12-24V DC switch expansion board (OneWire, DS2413)
Excl. Tax: €35.00 Incl. Tax: €42.35
OneWire controlled switch for 12-24V.
This board can switch two 12-24V actuators and is controlled over 1-Wire.
The board has 4 barrel jack sockets:
  • The 2 outer barrel jacks are power input or non-switched power output to the next board.
  • The 2 inner barrel jacks are outputs that can be controlled over OneWire
  • The outputs have a fatter center pin so you cannot accidentally connect your power supply to the outputs
This board is a drop-in replacement for the controller in the SS Brewtech FTSS kit. You can re-use your power supply, pump, and heater.
  • Can switch up to 10A.
  • The 12-24V output electronics are optically isolated from the OneWire side.
  • Outer barrel jacks are 5.5x2.1mm
  • Inner barrel jacks are 5.5x2.5mm
  • All RJ12 ports are bridged so you can use them to connect extra sensors/boards to the Spark.
