With a solid state relay, you can switch a large AC voltage with a small DC voltage. This SSR is for 3 phase current. Do not use this SSR without a heat sink. We sell a low profile heat sink that is compatible with this SSR.
These SSRs are high quality and come with a clear protective cover. They also have an indicator LED that shows when the SSR is on.
Specifications:
- Brand: LIRRD
- Type: LRSSR-3DA 20A
- Output voltage: 24~480V AC
- Input voltage: 3-32V DC
- Maximum current: 20A for each phase
- Maximum power at 230V: 13.8 kW
- Dimensions: 108.5 x 79.3 x 37.5 mm
