1/2" BSP 3-piece Coupler
Excl. Tax: €4.00 Incl. Tax: €4.84
1/2"BSP hex coupler that can be easily installed and taken aparrt
Hex coupler with 2x female 1/2" BSP thread,  to connect two male BSP parts.
This coupler consists of 3 pieces:
  • Two 1/2" female BSP end pieces
  • One threaded outer ring, which presses the 2 pieces together
A teflon ring ensures a good seal between the two end pieces.
The benefit of this 3-piece coupler is that you can freely rotate the pieces you want to connect, then just press them together with the outer ring. This also makes it a lot easier to take a part of your setup out for maintenance.
The spanner size for the outer ring is 35mm.
