Tri-clamp OneWire temperature sensor
Excl. Tax: €40.00 Incl. Tax: €48.40
Tri-clamp OneWire temperature sensor for the BrewPi Spark
This sensor can be installed on a standard tri-clamp (tri-clover) port/tee.
This sensor has a DS18B20 OneWire sensor inside with a detachable cable.
Specs:
  • Plug and play with the BrewPi Spark
  • Maxim DS18B20 sensor
  • RJ11 plug (fits in RJ12 socket)
  • 2m silicone detachable cable (high temperature proof)
  • Stainless steel SS316
  • Probe length 60 mm / 2.4 inch
  • 1" standard triclamp (50.5mm)
  • 0.0625 ºC resolution
  • Range of -55°C to +125°C
  • Factory accuracy of ±0.5°C over the range of -10°C to +85°C
  • With calibration via the BrewPi software, accurate to 0.0625 °C
Warning: not compatible with other PID controllers, like the STC-1000. These devices need an analog thermocouple sensor. This is a digital OneWire sensor.
