This power supply can be used to power TD5 (bigger) stainless brewing pump. Please select the correct plug/cable for your country. We only have EU and US cables at the moment. The cable used is a standard IEC 60320 C7 cable, so it should be easy to get one, if you don't already have an one lying around. Voltage: 17V Max Current: 2A Plug: 2.1mm ID, 5.5mm OD - Additional Information
Voltage 17 V Maximum Current 2 A - Reviews
